Re: H motor knocking
Posted by CNKS on July 04, 2008 at 17:24:01 from (216.144.104.128):
In Reply to: H motor knocking posted by Al in Mn. on July 04, 2008 at 16:33:19:
Are you sure that wasn't just detonation (pinging)? A more serious problem won't go away. That will be a rapid higher pitched sound, as opposed to only one knock per revolution if it is a more serious problem. You eliminate the pinging by reducing the load, or shifting down a gear. Your timing may be slightly advanced.
