Re: More W-6 questions
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Wardner on March 16, 2000 at 09:30:30 from (63.23.216.65):
In Reply to: More W-6 questions posted by Patrick Skelley on March 16, 2000 at 07:41:35:
I put a fast hitch on a IH 650 which is basically the same as a W-9. It is the next size larger than a W-6. I used IH parts and fabricated the rest. I attached four pics but they didn't scan very well.
For a 3-point, you will have to mount a rockhaft and some way to lift it. The current drawbar brackets that attach to the axel housing could be used to attach the lower links. If your W-6 is similar to my IH 400, you will have to remove the floor boards.
If you get a factory made 3pth. it would probably attach to the axel housings with large u-bolts that might be available at a truck spring shop. It would require a couple of radius arms to keep it from rotating If you can find a local tractor that has an aftermarket hitch, a lot of your questions will be answered. If you are near Tewksbury, MA you are welcome to look at some of my tractors. I have two Worksavers that fit H's and M's. BTW I think that the Worksaver site may have some drawings with measurements. A search here will bring up the url.
Post A Followup
: Re: Re: More W-6 questions
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
