Re: How do I get on board
Posted by HENRY E NC on July 05, 2008 at 04:42:33 from (216.119.6.31):
In Reply to: How do I get on board posted by Bob S. on July 04, 2008 at 19:43:32:
Also, I would immediately drain the oil, check the radiator to see if you are losing water maybe head gasket, or other problem. If the pan over flows then possibly something getting into oil. Temporarily use cheap oil to determine the problem. Be sure to change filter also . Sound as if you have a serious problem that should be addressed before you run the tractor any more. Henry. I had to replace radiator head gasket on mu 51. Henry
