Re: How do I get on board
Posted by Brownie 450 on July 05, 2008 at 09:27:38 from (216.51.158.151):
In Reply to: How do I get on board posted by Bob S. on July 04, 2008 at 19:43:32:
An addition to what Henry said, The nut on top of the steering bolster shaft [horizontal--not the worm gear] could be loose. It is a tapered spline, & the splines may be worn. Try tightening the nut first. If you run out of threads, put a proper size washer [shim] under the nut to see if that takes more play out.
