Re: How do I get on board
Posted by mkirsch on July 05, 2008 at 09:49:36 from (67.240.251.254):
In Reply to: How do I get on board posted by Bob S. on July 05, 2008 at 08:34:59:
That is the part number of the engine block, Bob.
The engine serial number is on a smooth flat spot, and it's stamped into the block. It is not raised letters.
First thing, change the oil. Drain it all out. Don't bother with the filter this time because you'll probably be changing it again soon. Just drain and fill until it runs out the bottom petcock. Any SAE30 oil is fine, even the cheapest SAE30 is way better than these tractors had new.
If it's starting easy and running smooth, don't touch the carburetor or ignition.
