Re: Super A right brake pedal
Posted by Gene Bender on July 05, 2008 at 12:34:56 from (67.55.226.165):
In Reply to: Super A right brake pedal posted by Kendall on July 05, 2008 at 10:43:14:
I use a torch many times when restoring one after doing the brakes and getting the bands adjusted. Its nice when using brakes to have both wheels stop together.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
