Re: Farmall H 12 volt conversion
Posted by tn terry t on July 05, 2008 at 13:43:25 from (205.188.116.144):
In Reply to: Farmall H 12 volt conversion posted by CHIEFEAVES on June 24, 2008 at 06:49:53:
Shahn said: (quoted from post at 16:14:20 07/05/08) How can I correct my wiring problem? I have a wire that goes from the ignition shut off switch to the resistor. If the wire does not go from the resistor to the mag, where should it go?
http://s101.photobucket.com/albums/m46/farmallbob/Farmall%20Tractor%20Wiring%20Diagrams/ go here and look for a conversion with the mag if you havent already burnt things up that post on the mag should have no connection with the positive side of the battery no resistors or any thing matter of fact it will run with no wire hooked to it
