Re: oil in water???
Posted by guido on July 05, 2008 at 16:03:04 from (71.168.241.164):
In Reply to: Re: oil in water??? posted by dave2 on July 05, 2008 at 14:25:26:
Hello Dave2
To find a leaking/weak cylinder you need to performe a leak down test.
Remove injector/spark plug Put pressure into each individual cylinder and time how long it takes for the pressure to go down. A bit of a time consuming procedure but it will show you which of the cylinders is leaking the fastest, and if the head gasket is leaking into the cooling system it will show as well. I would skim/remove as much as possible of the black stuff and run the h@#l out of it. get it to work under load I mean.It think it will be O.K.
GUido.
