Re: 300 International
Posted by john d on July 05, 2008 at 18:18:31 from (69.130.164.250):
In Reply to: 300 International posted by Pastor Ray on July 05, 2008 at 15:24:11:
Bob's correct on what it does. Assuming yours works, you can keep it working longer by shifting it correctly. Don't pull the lever back in an effort to try to slow the tractor when coasting in 5th gear. That's a shortcut to destroying that TA unit. It may be shifted forward or backward when under load with no problem. The shift should be reasonably quick. Trying to "ease" it forward has the tractor in both ranges momentarily, and will burn out the TA clutch over time.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
