Re: Farmall H 12 volt conversion
Posted by Wayne in MN on July 05, 2008 at 19:53:43 from (68.119.27.241):
In Reply to: Re: Farmall H 12 volt conversion posted by Shahn on July 05, 2008 at 13:14:20:
Tape it back into the wiring harness; it should not be used. Disconnect the wire in the switch box also since it is only to be used with a battery-coil type ignition.
