Re: Super A right brake pedal
Posted by Hugh MacKay on July 05, 2008 at 20:16:30 from (209.226.106.83):
In Reply to: Super A right brake pedal posted by Kendall on July 05, 2008 at 10:43:14:
Kandall: Adjust the brakes, I've never seen one of these that wouldn't even up with adjustment unless the brake band is broke. It may take a bit of heat to free up the adjustment.
If the shaft on the right brake is wallowed out, use shim stock. If shim stock is scarce, cut up a beer or pop can. It will make it tight as new for a fraction of the cost of machining and brass bushing.
