Re: 1948 Cub
Posted by banjo on July 05, 2008 at 21:01:17 from (65.67.203.35):
In Reply to: 1948 Cub posted by Steve Lambert on July 05, 2008 at 12:16:46:
there should be a inlet screen just inside the carb where the fuel line is attached, they get stopped up some times. see if you have a steady fuel stream with the plug removed from the front of the carb bowl.
make sure you have clean battery terminals and heavy cables to the battery, also check the connection on the starter.
