Re: Need duel hyd. to run bailer on 706
Posted by formerly ny bill on July 06, 2008 at 05:54:58 from (66.24.240.172):
In Reply to: Need duel hyd. to run bailer on 706 posted by robertmn on July 05, 2008 at 19:39:45:
i have a hyd multiplier on my 826 that i bale with. i have the tie side on the regular lever, the open door hoses on the button side. it works ok- the worst that happens is sometimes i start to tie again if i don't hit the button fast enough when i want to dump the bale, so it uses a little more string. the multiplier isn't cheap but it was a quick addition when i got it 10 years ago. another way to deal with it would be to mount a double valve on the fender and run it off the single 706 remote. thats the way my 1206 was set up when i bought it. make sure it is an open center valve if you do it that way.
