Re: anyone have a #
Posted by Daniel H. on July 06, 2008 at 11:19:40 from (66.226.34.159):
In Reply to: anyone have a # posted by tn terry t on July 05, 2008 at 19:38:18:
I believe the seal from Case/IH can be ordered with the wear sleeve. If you already have a seal, NAPA should be able to order a speedi-sleeve to fit the pulley. You have to measure the pulley:
[quote:0c41f62fe0]Correct size selection requires that three measurements be taken and averaged. Measure the shaft diameter just ahead of the wear path (not in the track worn by the seal) at three positions: 12 – 6 o’clock, 2 – 8 o’clock and 2 – 10 o’clock. The average of these readings will compensate for an out of round shaft. Compare your average diameter with the size ranges in the Speedi-Sleeve Selection Charts, and choose the appropriate sleeve.[/quote:0c41f62fe0]
Here is the link to the sleeve sizes:
http://www2.vsm.skf.com/Files/Brochures_in_PDF/Speedi%20Sleeve.pdf
