The main problem is the cast aluminum pistons that are only availiable for rebuilding these engines nowadays. When they were first manufactured IH used forged pistons. If you know anything about motors you know forged pistons are alot more consistent when they heat up. I have a 263 706. If I use it for light work on 87 its fine, but if I would run it hard say at 90% load on 87 the cast pistons would swell and score cylinders, BTDT! 87 octane burns fast creating allot of heat in the piston, more than it can get rid of causing it to swell. 93 octane burns much slower and cooler. If you don't believe the Vet get an IH 6 cylinder gasser hook it to a plow, put in 87 and go to work. I guarantee you will be hearing all kinds of strange noises as the cast pistons start transferring metal within a few hours..
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
