Posted by Gene Bender on July 06, 2008 at 17:11:08 from (67.55.226.165):
In Reply to: Re: SA Steering posted by don g on July 06, 2008 at 12:02:09:
Dont know why it wouldnt work. I have done a bunch of them both the A and B have had success with the 150 gear lube just as long as it gets to the bushings and the worm runs fully in the lube sure steer great when done. I have also foun that replacing the input bearing with a new seal in the tranny does quiet down a bunch if that bearing has play. The final drives are straight cut and were noisy when new but the 150 will quiet down some noise. good luck.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
