Re: Farmall A generator question
Posted by 55 50 Ron on July 06, 2008 at 17:38:37 from (216.114.212.98):
In Reply to: Farmall A generator question posted by bigr on July 06, 2008 at 16:50:48:
The word that needs doing is "polarize". It's done by using a short piece of wire and touching the bare ends from the voltage regulator BAT terminal to the A terminal, Just touch it momentarily, there should be a small spark. Don't hold the wire there after you see the spark. If it doesn't charge after that, try grounding the FLD terminal to the generator case. It should show charge if the generator is good. That would indicate that your voltage regulator is probably bad or as you mentioned your ammeter could be bad. Probably the very first thing to do is to clean ALL your connections, then do the other suggestions.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
