Posted by CNKS on July 06, 2008 at 18:00:10 from (216.144.104.128):
In Reply to: paint question posted by Pat-CT on July 05, 2008 at 20:21:47:
2150 can be mixed by PPG (71310), or DuPont 96766, or NAPA/Martin Senour (Don't know number). At a minimum use Omni (PPG) or Nason (DuPont) acrylic enamel, acrylic urethane with hardener is better, but requires a supplied air breathing system -- some people say no, but I will not recommend hardener to anyone without supplied air. Tractor store/hardware store paints are alkyd enamel and do not last unless waxed frequently or kept inside. CaseIH sells 2150 in an "acrylic modified" version of alkyd enamel. It is ok because it contains UV inhibitors to prevent fading, the main problem with the older alkyd enamel. I would remove the brown primer and use epoxy -- the primer on it now may or may not be compatible with the paint you use. And epoxy is waterproof, your "brown primer" whatever that is likely isn't.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
