Round bales or square? I use a Farmall 504 Diesel to bale 4'x5' bales(800-1000 lbs) with a Vermeer 504C. I have used a MF 135 Diesel on the same baler and also a NH square baler (245? Hayliner). A 5' disk mower is fine with a 45-50 hp tractor, a 7' requires more as will larger balers. As for the side delevery, an 8N will pull it.
Live PTO, 3-point, and power steering would be my reqirements as a minimum. A TA or two range transmission is a definate plus. Diesels use less fuel per HP than gas and eliminates the carb and ignition to maintain.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
