Re: Farmall A generator question
Posted by Janicholson on July 06, 2008 at 19:59:12 from (66.173.50.13):
In Reply to: Farmall A generator question posted by bigr on July 06, 2008 at 16:50:48:
If the needle moves to - when the lights are on and the tractor is not running, The gauge is probably OK.
If it never moves, the gauge could be bad, or the gauge could be connected with some of the wires on the wrong terminal. Check the charging voltage at the battery. When running 1/2 throttle or more. It should be 7.2 to 7.3 volts. JimN
