Re: Dual action cylinder hook-up
Posted by Janicholson on July 06, 2008 at 20:16:52 from (66.173.50.13):
In Reply to: Dual action cylinder hook-up posted by Randy D. McClenahan on July 06, 2008 at 09:59:40:
It is possible to do.
Use a open center spool valve for two way. Connect the return line to a "T" in the drain plug of the Liftall, not the top. Putting it in the top will spew oil from the vented cap.
Pull the main control lever back, and wire or fasten it in that position. I do not know the answer to the valve you have, but I think it allows for two different one way cylinders. (I may be wrong on that) JimN
