You need to make sure you're getting gas into the carburetor. If that carb has a plug in the bottom remove it and hold a clean container under it to catch the gas. Should have a full stream of gas. If it doesn't unhook the gas line at the carb and check it for a full stream. If that's ok, remove that tube fitting where your gas line came off. Be careful you don't crush the fitting. Look for a screen behind that fitting. It could be blocked with rust & crud. Hold your hand over the throat of the carb and see if there's good suction on your hand. The tractor may start if the ignition is on. I would remove all the sparkplugs and squirt engine oil into each plug the crank over the engine and shoot some more oil in there and replace the plugs. If there's not much suction on your hand is a sign there's not very good intake manifold vacuum. This is needed to suck that gas into the engine. Low vacuum could be worn sleeves, rings and valves not seating. A compression check will tell you what shape the engine is in. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
