Re: FARMALL 200 STARTING PROBLEMS
Posted by Dave BN on July 07, 2008 at 17:17:24 from (205.188.116.73):
In Reply to: FARMALL 200 STARTING PROBLEMS posted by Joe Reusch on July 07, 2008 at 13:32:03:
How did you check the timing? Are you sure your getting spark at each plug? You can pull the plugs out and hold each plug against the engine block one at a time and see if your getting a good, bright blue spark as you turn the engine over. Dave.
