Re: Gasoline Stabilizer Question
Posted by RustyFarmall on July 07, 2008 at 17:17:31 from (209.152.78.71):
In Reply to: Gasoline Stabilizer Question posted by Ksfarmmer on July 07, 2008 at 16:28:57:
I've got an H that runs at least once a week for an hour and a half all through the summer mowing season, and then just sits all fall and winter. I have never used a fuel stabilizer and the tractor always starts right up the next spring. I do agree that todays fuel is not the same as it was 40 or 50 years ago, but it is not as bad as that fellow told you.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
