Re: Wiring H light switch and ammeter
Posted by boomer22 on July 07, 2008 at 19:49:05 from (199.120.77.167):
In Reply to: Wiring H light switch and ammeter posted by boomer22 on June 28, 2008 at 06:41:10:
I put new brushes and brass sleeve in the generator. Put on a brand new VR (6volt positive ground). Hit the kill switch and it moves towards negative ground start her up and it move more to the negative side. Tried motor test on gen and it spins (however it didn't seem to speed up when i removed the F grounded wire, but it was turning pretty fast either way). So inconclusion it didn't do anything more then it was before. I was wondering (grasping at straws here) would it make any difference if the wire comming from the ammeter to the VR is only a 12-14 gauge instead of the 10 gauge?
Also I have ohm'ed everything and everything seems to be making a good ground generator, VR, even ammeter case.
This post was edited by boomer22 at 19:52:19 07/07/08.
