Re: hot coil on H
Posted by El Toro on July 08, 2008 at 04:15:27 from (205.188.116.73):
In Reply to: hot coil on H posted by Andy from IN on July 07, 2008 at 18:31:44:
You need to check for battery voltage at the small terminals on the coil using a volt meter or test light with the points open and the ignition switch on. If there's voltage on both terminals
pull the coil wire from the distributor cap and hold near a good ground, then have someone to snap those points open & closed several times and see if there's fire from the coil wire. Hal
PS: Rub those points with some 320 wet or dry.
