Posted by mkirsch on July 08, 2008 at 04:48:51 from (64.80.108.52):
In Reply to: hot coil on H posted by Andy in IN on July 08, 2008 at 04:11:47:
New points, condensor, distributor cap, spark plugs, and wires should be standard operating procedure for a "restoration" or "rebuild." If you're not replacing those basic, critical parts, what exactly are you "rebuilding?"
Please, don't waste your time dragging the tractor all over heck's half acres trying to get it to start. If a gasoline-powered tractor doesn't pop right off and run within 10 feet, there is something wrong that needs to be fixed. Towing it for "5 minutes" won't change that. Freud defined insanity as performing the same action over and over, expecting different results...
Why aren't you using the starter? The same reason the starter doesn't work (bad/weak/dead battery) may be why you don't have any spark. If the battery isn't producing enough voltage, the coil won't build up enough charge to pop off a spark.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
