Re: What to use to cut off Axles on Farmall 450 ?
Posted by Randy in NE on July 08, 2008 at 05:26:06 from (204.124.192.32):
In Reply to: What to use to cut off Axles on Farmall 450 ? posted by migraine on July 07, 2008 at 21:23:54:
What about replacing one of the axles so that they match? A salvage yard should have one.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
