Posted by Don Swindall on July 08, 2008 at 05:35:08 from (208.35.38.11):
In Reply to: 1941 m hydrolics posted by El Toro on July 06, 2008 at 14:46:37:
Frank in texas said: (quoted from post at 22:46:37 07/06/08) I have had my m for some time but never used the hydro lift system. I finally bought a 7ft blade and a boom pole for it. The system works without weight in the lift arms, but even the small weight of the boompole it wont lift. What could be the problem? I checked the pump oil and it seems to be ok.
Frank, I have the same porblem with my IH-100. I replaced the unit under the gas tank, with one from a salvage yard. It was not much better than the one I originally had on there. I took it back and they rebuilt my old one, again with no success. It would lift me, 190 lbs, with no porblem but hook up the 5" disk and it would lift it almost clear of the ground. I could pick up on the back of the disk and help it and it would lift real high. I ordered a pump which should be here in a few days. I sure hope that fixes the problem. Starting to get real expensive $150.00 for the rebuild and $385.00 for the pump. If it doesn't work this time, if I want my wife to know, I will tell her. Good Luck, Don
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
