Re: power steering flow
Posted by Steven f/AZ on July 08, 2008 at 08:11:43 from (209.188.76.19):
In Reply to: power steering flow posted by Chris NW Ind on July 07, 2008 at 16:20:45:
Chris NW Ind said: (quoted from post at 16:20:45 07/07/08) Unless your tractor is set-up goofy, power-steering uses a dedicated pump piggybacked to the main hydraulic pump. You shouldn't have to divide the flow.
Chris B.
The 460 only has one pump. The 706/806 and newer are the ones with separate pumps for different items.
Keep in mind that you probably have the (I think) something like 12 GPM pump on there most likely and your hydraulics won't set any speed records.
I'm not sure if the 460 is something that can be upgraded to the 17 GPM pump or not...
