Re: hot coil on H
Posted by labman98 on July 08, 2008 at 09:40:04 from (65.216.74.168):
In Reply to: hot coil on H posted by Andy from IN on July 07, 2008 at 18:31:44:
I agree that you need to see if you are getting juice to the coil. Use a test light or volt meter. Either will work. If it is warm it should be getting jucie. Then test for spark by pullin gth coil wire from the dist. and holding to ground while you turn over the tractor.
