Use a pipe wrap to mark the circumference, then use a Porta-Band. Start the cut at the top then "roll" the saw around making a scribe around the shaft. Once the starter line is scribed, just walk the saw around until completly cut through. A recipricating saw can be used using the same technique.
I liked the idea of counter-boring to imitate the dead center hole. Good luck.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
