The best way is to use a chop saw. however jack the tractor off the ground and remove the wheel on the side you want cut. Put the tractor in a very ;ow gear. You want to cut the axle while the shaft is rotating. This precents overheating and also ensures that the cut end will be perfectly straight. Do not try to cut the axle without rotating it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
