Migraine: You speak of this K date code, what is the K on, axle or axle carrier? K code would be 1965, much to late for a 560. I'm not sure a 656 axle carrier will bolt up to the older chassis. the axle may work, not sure? If the K is on the axle carrier, I'd have more faith that it came from a 41 M.
That being the case you best check the length of axle carriers, as well as axles before you do any cutting, I don't know about M, SM, 400, etc., however in the case of H, SH, 300 and 350 there are differences in both axle and axle carrier length. H had shorter axles, and it also had shorter axle carriers than 300 or 350. I'm talking standard axles in all cases.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
