Re: 350 Utility Indep PTO Slipping
Posted by Roger46 on July 08, 2008 at 18:50:42 from (69.58.159.91):
In Reply to: 350 Utility Indep PTO Slipping posted by Formerly PaMike on July 08, 2008 at 17:38:31:
There are two bands in the Independent PTO unit. One is for stopping the implement and the other is for engaging it. Follow the instruction in the manual and it should correct the problem. It is a fairly easy adjustment. If that doesn't work, replacing the bands is not an option unless you have a lot of money. Case/IH wanted $300+ for each band and several other places wanted in the high $200's each. I got mine relined at a brake shop for about $100 for both. Roger
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
