Re: 10SI alternator
Posted by Bus Driver on July 09, 2008 at 04:18:07 from (66.226.58.196):
In Reply to: Re: 10SI alternator posted by Bob M on July 08, 2008 at 10:20:17:
Agreed about this list of vehicles. The Chevette used the same alternator, electrically speaking, but the housing for the Chevette has longer "ears" down to the base swivel bolt. Depending on application, that could be either an advantage-or not.
