Re: Farmall M Smoking Problem
Posted by El Toro on July 09, 2008 at 05:26:14 from (205.188.116.73):
In Reply to: Farmall M Smoking Problem posted by Jim R on July 09, 2008 at 05:13:10:
Doing a compression test will give you an idea what shape the engine is in. It may be time to
rebuild the engine. I would keep a close check on the oil level when working the tractor. Hal
PS: It could be worn sleeves, rings and valve guides.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
