Re: Distillate instead of Gas??
Posted by Janicholson on July 09, 2008 at 06:20:17 from (199.17.6.136):
In Reply to: Distillate instead of Gas?? posted by oldnnew on July 08, 2008 at 14:55:55:
As others point out, all fuels are about the same cost per unit volume if petro based. An engine designed to run on gasoline will be a non starter on other heavier oils. The worst case is dammage to the internals, and less efficiency.
Distillate was residuals from processing gasoline from crude when catylitic cracking was not available. It was not a intentional mix as much as a leftover. That made it cheap.
Now we use high technology materials to get the last ml. out of a barrel. Bio fuels (ethanol based), up to about 25 or 30% with richening adjustment to the jets, can be operational.
JimN
