Re: oil getting in carb? farmall 100
Posted by RustyFarmall on July 09, 2008 at 12:32:23 from (209.152.78.71):
In Reply to: oil getting in carb? farmall 100 posted by farmaller 11 on July 09, 2008 at 11:44:40:
Worn valve guides is usually the cause of that one or two minute smoking and will never lower the oil level by any detectable amount. It will get worse over a very long time, but basically is nothing to worry about. The drip on your finger is from a varnished up fuel bowl on the carburetor. It will seem to be a bit oily in nature, but again, if the tractor is otherwise running just fine, don't worry about it.
