Posted by Doug - Iowa on July 09, 2008 at 18:56:32 from (208.126.6.138):
In Reply to: 706 choking out posted by 706PoorDave on July 09, 2008 at 16:51:03:
My 706 did the same thing. The gas tank had bits of rust in it that plugged the intake to the sediment bowl fitting. Even though the sediment bowl had little rust in it, the inlet was the problem.
Have a bucket ready and take out the entire sediment bowl assy from the tank. All the gas (and hopefully some of the rust) will come out. Look at the inlet of the fitting, there is a disk staked into the center. Under the disk are two slots the fuel enters the valve. This is where mine clogged. After two cleanings, I finally solved the problem by cutting the disk out and extending the inlet with a piece of copper tubing 1/4" dia by 1" long. This abandons the bottom 1" of your tank capacity. Apparently, the rust can't jump that high as I've had no more problems.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
