Posted by MN Dave2 on July 09, 2008 at 19:59:33 from (204.221.132.81):
I have a carb on a Super H that is enough to make a preacher cuss. Tractor will appear to be cured, sometimes will work for 30 minutes and the next time will flood right away.
I've already blown out/cleaned carb, replaced the float (old float sure looked ok, but I'm past flustrated), replaced the needle and fitting (twice) that float opens and closes to allow gas into carb. Float is not touching/hanging up on inside of carb. Float needle seems to hang up sometimes, but is loose in new (and also old) fitting. Both the little hard rubber tip on needle and the brass fitting that it fits into look perfect. Last time we worked on it, tractor started up fine, flooded so that it would only run with choke 2/3 closed (warmed up tractor... totally no need for choke) tractor ran poorly until I turned off gas under gas tank, then ran fine until it ran out of gas. Gas is tank is not under pressure... Thanks for the help!!!!!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
