Re: IH 140 Governor ?
Posted by Hugh MacKay on July 10, 2008 at 01:27:08 from (216.208.58.109):
In Reply to: IH 140 Governor ? posted by AJ 140 on July 09, 2008 at 06:16:19:
AJ: You say stick, stick where, low idle, high idle or somewhere in between? Give a bit clearer description of exactly what it"s doing.
The governor is designed to control low and high idle rpm as well as making it steady at the position you set throttle.
I doubt if your problem is adjustment, governor probably needs some rebuilding, unless someone has been playing with adjustments.
