Re: 706 choking out
Posted by Janicholson on July 10, 2008 at 09:19:39 from (199.17.6.136):
In Reply to: Re: 706 choking out posted by mark on July 10, 2008 at 08:03:07:
AHH that is the reality.
I feel that the temps found with 87 would be operational as well. A Triumph 750cc twin needs .010 piston clearance when cold. Its pistons swell .0085 when running under load.
Tractors run under full losd for hours at a time.
If they have preignition, or excess heat from poor cooling system operation, they will melt down. I do believe (in contrast to The Tractor Vet.) that the proof is in the detonation actually found in the engine, and the exhaust gas temp found. Gasohol also needs a bit more fuel to compensate for its reduced thermal content. JimN
