MOUNTING A IH SICKLE MOWER ON A CUB
Posted by TIM HIBEN on July 10, 2008 at 16:03:23 from (216.222.173.87):
HI, I BOUGHT A CUB AND STARTED MOUNTING THE SICKLE MOWER ON IT AND I THINK I AM MISSING A COUPLE DRAG RODS THAT CONNECT FROM THE MOWER TO THE CUB AND HAVE A LIFT MECHINISM BUT NOT SURE WHERE THAT MOUNTS . I HAVE IT HOOKED UP TO THE BELLY OF THE TRACTOR WITH THE TWO BOLTS AND THEN BOLTED THE PTO SHAFT TO THE PLANITARY. DOES ANYONE KNOW OF A SIGHT TO SEE A DIAGRAM OF ONE THAT IS MOUNTED ON ?THANKS
