Re: Super C Carb issues
Posted by jake w on July 10, 2008 at 17:01:31 from (151.205.237.72):
In Reply to: Re: Super C Carb issues posted by Joe Kimbriel on July 10, 2008 at 16:33:19:
It actually has the air screw at the top left of the carb and down at the bottom left it has a T shaped shaft that I guessed would be the main jet adjustment. The inside of that shaft is hollow with small holes around the diameter.
