Re: M 12v conversion
Posted by John T on July 11, 2008 at 04:28:38 from (66.244.97.31):
In Reply to: M 12v conversion posted by tcanthonyii on July 10, 2008 at 22:00:29:
On a 12 volt system, which coil set up is your choice. EITHER a 6 volt coil with an external series voltage reducing (12 to 6) ballast resistor ORRRRR a full true 12 volt coil (some folks refer to as internally ballasted) no external ballast required. It would be cheaper to just buy and add the ballast but if you need a new coil, prob cheapoer to just buy a 12 volt n be done with it.
John T
