Re: Do all Farmall H's have hydraulics?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by gene on March 17, 2000 at 04:17:32 from (63.25.167.11):
In Reply to: Do all Farmall H's have hydraulics? posted by Paul on March 16, 2000 at 18:29:01:
they had a pump behind the clutch before the trans it was not live works when clutch is released side port on right side is output front on the left side is the same the plug to the rear is delayed atcion is not two way best is to put a pump between the block and the dist or mag which ever you have get some one who knows FARMALLS to help a rear blade can be used without a three point and two way cycl easy to do
Post A Followup
: Re: Re: Do all Farmall H's have hydraulics?
