Posted by mkirsch on July 11, 2008 at 10:16:16 from (64.80.108.52):
In Reply to: Farmall Super A posted by Greg Morris on July 11, 2008 at 06:20:22:
Greg,
2 bars extending from WHERE? If they're just extending from the fenders, that is the rear rockshaft for lifting cultivators and other A-specific rear-mounted implements.
If these two bars extend from brackets on the axle housings, and connect via chains or linkages to the rear rockshaft, then you have a homemade or aftermarket 3pt hitch. Only these two lift arms are permanently attached to the tractor on a 3pt. system.
The third point, called a top link, is an adjustable bar that attaches to a bracket above and between the lift arms on the back of the tractor.
I suspect the seller was either an idiot or lying to you. You probably just have a rear rockshaft. I've seen several Super A/100/130/140 tractors on craigslist recently claiming 3pt hitch, but the rear views all show a standard rear rockshaft and drawbar.
You can add an aftermarket 3pt hitch from a company called Worksaver, but it has limited usefulness. With the high offset PTO, there are not many PTO-driven 3pt implements that will work.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
