Re: 574 clutch adjustment
Posted by JimB2 on July 11, 2008 at 18:57:53 from (99.241.179.24):
In Reply to: Re: 574 clutch adjustment posted by Jeef on July 11, 2008 at 01:00:25:
Hi Jeef, did a 684 about 3 years ago and parts are about $350.00.
Are you sure the clutch linkage is not binding or the clutch release bearing carrier is binding.
There also should be a clutch return spring from clutch pedal to frame under the dash.
There is an inspection plate that can be removed on the bottom of clutch housing and with a light you can inspect the mechanism.
Usually the clutch on those tractors start to slip when going up a hill in 4th high.
JimB
