Re: Removing Fluid From Tires-Best Way?
Posted by Hugh MacKay on July 12, 2008 at 02:20:16 from (216.208.58.135):
In Reply to: Removing Fluid From Tires-Best Way? posted by big red 1 on July 11, 2008 at 06:58:39:
Randy: As I understand it these tires and rims are no longer on tractor? When I did a set of these 24" tires, I got rim on top of two open barrels, with valve stem pointing into one of the barrels. These were plastic barrels.
Remove the stem with air still in tire, you'll probably loose stem in bottom of barrel. Stick a 2x4 under opposite side of tire from stem. Forget about it for 24 hours, it will drain. You can speed it up by putting stem back ocasionally and adding air.
I save the calcium chloride for dust control on driveway and yard.
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
